DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Year 4 on the winder coming up. (Time sure flies!!)
I havent really blown belts other than during testing which I consider self inflicted. However, I just purchased Hurricanes alignment bar to see how my offset is. I am at 60.65mm.
Trying an O-S-O spring to try and pick up a couple hundred rpm on my dtya1s while running the stock muffler tunes.
Picked up a MBRP race exhaust for playing on the lake.
Ordered a new 22T gear with the oil holes and a Cat 229 center shock spring.
BOP driveshaft wedge, upper and lower RR shafts and tunnel support plates.
I also grabbed the biteharder stud sharpener so hopefully it works good so I can get at least another year out of my studs.
I have ran the 41-35 dalton helix for 2 years. Might try something different, any suggestions???
Installed Thunder rollers in primary and replaced all the plastic washers.
Who else is as excited as me for snow!!!
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Nice!
My plans thus far:
BOP driveshaft bearing lock
BOP lower cross shaft
Shock revalve
Align clutches
Maybe:
Mountain Seat(I'd like to sit on one before I purchase one)
Tune with supporting mods
I'm on the fence with the tune. My sled is still under warranty for this season. It will already be going in for a new driveshaft and drive bearing. Once that warranty is up though, its game on!
My plans thus far:
Shock revalve
Align clutches
Maybe:
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I ended last year the HAPPIEST i've ever been on a sled. It now has over 10,000 miles.
But i pulled some studs so i'll be tearing it down for some minor changes.
-new track & fresh studs
-freshen up rear shocks with small calibration
-BOP tunnel hose covers since mine blew out last year
-new top gear with different make bushing
-weld the tension wheel
-BOP "brake bearing holder thingy McWedgy" (if he ever gets off his lazy #*$&@ & gets it done......LOL)
-new bushings in clutch rollers & maybe weights
-new bearings: brake, stub shaft, all in the gear case & whatever i find in the rear suspension
P.S: The shot fired at Travis is obviously sarcasm since i don't think he's left the shop since the Winder hit the snow
P.S2: I don't think Travis actually makes money off his inventions, but i think he likes to show off his engineering skills with just a GED
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
We have shared clutch settings before I think DMC. I also have the dtys1s cut down to 72 grams,and also Dalton 41-35,now the Yamaha o-s-o primary spring you have to run,what was your intent for that spring,softer engagement and maybe more full shift rpm? What was your full shift rpm with your set up from last year,using the dty,s and 41-35 ? What was your secondary wound with and at what wrap?Year 4 on the winder coming up. (Time sure flies!!) I havent really blown belts other than during testing which I consider self inflicted. However I just purchased Hurricanes alignment bar to see how off my offset is. I am at 60.65mm.
Also picked up a O-S-O spring to try and pick up a couple hundred rpm on my dtya1s while running the stock muffler tunes.
Also picked up a MBRP race exhaust for playing on the lake.
Ordered a new 22T gear with the oil holes and a Cat center shock spring.
I need a second job to purchase all of BOPs awesome fixes for this sled. Some will have to wait till next off season.
I have ran the 41-35 dalton helix for 3 years. Might try something different, any suggestions???
DMCTurbo
- Nov 12, 2005
I ran the dalton black teal last year. My thoughts with the O-S-O are that its short so its easy to get the cover on, it'll have a lower engagement than the dalton black teal and I'm hoping it'll gain me a couple hundred rpm at full shift.
I went with a Yamaha spring only for cost savings as I find the shipping a little pricey for a single spring from dalton or anywhere for that matter.
I run the dalton gen 1 black orange at 6-1.
Turboflash
- Mar 18, 2019
- Southern MN
Installed Stage 4 PEFI 320 HP kit. Should be a sinister animal. Can't wait to take her for a spin once it snows!
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
-BOP hose guard
-BOP front tunnel saver
-BOP chain case protector
-BOP rear tunnel stiffner
-replace and add lots rivets to bumper and heat exchanger
-realign the rear part of the frame where suspension is fixed ;-/
- new snowtracker extreme on my CAT ski , the last set have done +/~11 500km
-new slides
- better heatshield under gaz tank +oil tank
-new lower bushing center shock
- new boost intake T clamp
-more wheel in suspension, trying to fit 2X 2,75 inches wheel in front of center shock +2 wheel ~~3,4inches in front of the last one
-new red duct intake front
-slider in chaincase for the "U"fork
-I am not talking about my clutche because i am giving them some love after almost each ride...lol
- I have asked Santa Claus tomcat Adjustable bov
-new slides
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
where did you grind on cam arm?We have shared clutch settings before I think DMC. I also have the dtys1s cut down to 72 grams,and also Dalton 41-35,now the Yamaha o-s-o primary spring you have to run,what was your intent for that spring,softer engagement and maybe more full shift rpm? What was your full shift rpm with your set up from last year,using the dty,s and 41-35 ? What was your secondary wound with and at what wrap?
Sly99
got a new to me 2017 sidewinder BTX, already have TD tune, clutch kit, strait 3 inch exhaust, cold air intake.
upgraded the exhaust with a 3 inch vibrant resonator
better position for the CAI
Rox hand gard
will check the rear skid as i have a small bend in the tunnel
BOP Part:
Center shock cross shaft
rear tunnel savers(black rivet),
tunnel safer kit,
intercooler guard(black)
Seat screw,
chaincase protector,
skid plate full version.
Belt Adjuster & Belt Change.
Hose Savers
driveshaft saver bearing
That will keep me busy until the season start lol
Rox hand gard
BOP Part:
tunnel safer kit,
Seat screw,
Hose Savers
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
On the undeside or bottom.where did you grind on cam arm?
DMCTurbo
- Nov 12, 2005
Tried the biteharder stud sharpener, the standard version and it works great. Just waiting for my BOP order and she can go back together.
- 9K
