Ohlins or Custom Axis....?
gormleyflyer2002
Newmarket, Ontario
anyone have experience with either.
not a OEM or stock Ohlins but a custom shock with high and low speed adjustment....?
thanks guys/gals.
thanks guys/gals.
I have a set of both for my rev. I also have a roehrig shock dyno so I have tested all my shocks. I would say they are about equal in adjustability. Both rears and the center ohlins are triple adjust(high/low comp and rebound adjustable) the center custom axis is low speed only. I have alot better luck dealing with the guys in reading pa than I do with ohlins. Ohlins seems tight lipped on the valving specs etc. All these shocks have alot better range of adjustability thans stock clicker shocks like doo hpg's.
