snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I have a 06 apexgt and the rear spring,as far as i can see is 08/48 L076 and i have an other ohlins spring from one of my other gts but i cant seem to get a good measurment of the wire on the one installed,so my question is,which one is a heavier wire spring,the L076 or the 08/48 L246 thanks.
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
Pete, dont know if this will help or not?
Öhlins® / GYTR™ Monoshock Springs
Springs are yellow. Fits Öhlins EC monoshock models only.
Item Item Code M.S.R.P.
Öhlins® / GYTR™ Monoshock Springs - (Rate 5.5)
GYT-8GD47-00-00 $101.95
Öhlins® / GYTR™ Monoshock Springs - (Rate 6.1)
GYT-8GD47-14-00 $101.95
Öhlins® / GYTR™ Monoshock Springs - (Rate 6.5)
GYT-8GD47-16-00 $101.95
Öhlins® / GYTR™ Monoshock Springs - (Rate 7.1)
GYT-8GD47-10-00 $101.95
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks,but those numbers are not what my springs have written on them.Shiek said:Pete, dont know if this will help or not?
NY AttakGT
These are the Ohlins #'s for the Springs and rates (below). You have a 696-08, which is the stock 4.7kg spring on the Apex. The 696 is constant # identifying the spring type. The 2nd number (696-XX) is the rate, which is variable on the different springs. Higher the 2nd #, the stiffer the spring.
696-08 48 N/mm (4.9 kg/mm) Apex GT stock spring
696-11 54 N/mm (5.5 kg/mm)
696-14 60 N/mm (6.1 kg/mm) Attak GT stock spring
696-16 64 N/mm (6.5 kg/mm)
696-19 70 N/mm (7.1 kg/mm) RX-1 GT stock spring
696-21 75 N/mm (7.6 kg/mm) Warrior GT stock spring
696-24 80 N/mm (8.1 kg/mm)
ohlin spring
mnmsnowbeast, if your looking for the next spring I have one that I no longer use. Would be willing to part with it at half price
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Re: ohlin spring
Thanks but i was just wondering what the extra one i already have was! Thanks anyways.deweysgt said:mnmsnowbeast, if your looking for the next spring I have one that I no longer use. Would be willing to part with it at half price
