Oil Change 23 XTX
XTX8550
Chicago NW Suburbs
2023 XTX LE
Just did the first oil change on my XTX Sidewinder. I put the required 3 quarts in and oil was still below MIN line after it was warmed up. I had to add almost close to another half quart, now its reading in the middle. Anyone else have this issue? How accurate is this oil level sticker?
It’s closer to 4 litres I find.
By the time I drain the lower oil hoses, and add new filter, it takes 4 to reprime the system
You’re good
Ms
Same here, after draining mine takes 4 qt to get just below the max line.
