Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
I'm assuming because of the same motor artic cat oil change kit is the same as the Yamaha one?reason I ask as no Yamaha dealer around here and the Artic cat dealer near me couldn't give me a answer.
mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
If the filter has already been changed once it likely won't need to be changed again. I believe the manual says every 12,ooo miles. Use Mobile 1 oil. I've been using Mobile 1 0W- 40 in my four stroke Yamahas since 2008.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I just go to the auto parts store and get a filter and some Mobil 1.. It's a lot cheaper.
Filter is:
Fram PH6017A
K&N 147
I'm sure there are others too.
Filter is:
Fram PH6017A
K&N 147
I used AC kit once when I was waiting on the kit from sled purchase.
Cfpdscott
- Feb 23, 2016
- Illinois
- 2016 Yamaha viper Rtx-se
5 quarts of mobil 1 0w-40 for sale at Walmart for 24 dollars and k&n filter was like 8 dollars if you're looking for a cheaper option
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
cat kits i use say yamaha on the filter if thats any indication
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
If you use a filter that is not Yamaha make sure it has the bypass valve in it!!
Cfpdscott
- Feb 23, 2016
- Illinois
The k&n kn-147 does. It says so on the boxIf you use a filter that is not Yamaha make sure it has the bypass valve in it!!
Carla 123
- Feb 27, 2017
- Lester beach
50 here in Canada at wallymart for mobile 1 and 4.4 litres at that5 quarts of mobil 1 0w-40 for sale at Walmart for 24 dollars and k&n filter was like 8 dollars if you're looking for a cheaper option
Cfpdscott
- Feb 23, 2016
- Illinois
I'm sure it's a special Canadian blend. Much better than what we have in the states50 here in Canada at wallymart for mobile 1 and 4.4 litres at that
Crazy Canuk
Can be found pretty regularly at Can Tire on sale for a little under $34 if you are looking for some. That is where I get mine.50 here in Canada at wallymart for mobile 1 and 4.4 litres at that
Crazy Canuk
It has a Maple Syrup additive for easier starting hahaI'm sure it's a special Canadian blend. Much better than what we have in the states![]()
