Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
How many quarts in the kit and what 3 gaskets listed?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks, shall do the same and not overfill!Just did my 500 mile oil change and once its all drained you add 3 quarts to the oil tank and then start it up. I let it idle until warm and then turned it off. Once it cooled down I had to add another 1/2 quart to get it to the top off fill line.
Really makes me wonder what he was reading when I was told 4.2 quarts???
And why they do not offer the oil change kit??
Oh well again this site has the most current and relevant info!
Thanks a bunch guys.
Pstn head
4 quarts, only 2 gasgets come with the kit 1 for drain plug on oil tank and 1 for engine drain bolt, if your thinking the third gasket it's already on the oil filter, just like an automotive style filter.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Check out the accessories catalog. Says, Oil Capacity, oil and filter- 4.85 US Qt, Viper and Sidewinder. Another screw up?
ritchie
- Nov 3, 2014
- Seven Sisters Falls, Mb
- 2017 Sidewinder Ltx Le
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I think it says check when hot, so that would mean you don't need to wait overnight, you check it a few minutes after shutting down. And if it goes up a little bit overnight no worries.
yamahaex50
- Jan 6, 2005
- Pittsburgh, PA
- Sidewinder LTX-LE
Dealer did mine and it does the same thing. I've put 1200 miles on since then and it hasn't been a problem.How long to you wait to check your oil level. It seems if you wait overnight the level rises. I had my dealer change the oil and after sitting overnight the level rose. see photo
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
big book says 0w30 performance semi-synthetic, 2.9 liters without filter (3.0644 qt), 3.1 liters with filter (3.27573 qt) for all models.
355 ml gear oil in chain case (0.375124 qt or .75 pint).
ritchie
- Nov 3, 2014
Manual is a bit vague says to heat up to operating temperature then shut off engine and let cool. Just seems weird that you can't check engine when cold and that it would rise like that.I think it says check when hot, so that would mean you don't need to wait overnight, you check it a few minutes after shutting down. And if it goes up a little bit overnight no worries.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yeah I found it takes just a bit over 3 quarts.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
for those interested.. a dealer told me they fill to a tad below the red full line...seems the higher boost sleds, boost vacuum was drawing some oil in...
might go the mobil one route like in the past with an emgo 10-82250 filter
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I have never changed any of the o rings on any of my sleds, cars or trucks and have never had a leak. Just make sure there is no grit or anything on the o ring or the bottom of the engine or oil tank drain hole. I see no reason the change them unless you damage it.
- Sauk Prairie, WI
- www.ty4stroke.com
So do the O rings need to be replaced each time we change oil? I don't remember having to do that on my other Yammy 4 strokes. Anyone got a part number from orielly or size of those O rings? I didn't buy the kit because I want to run Mobil 1 and the K&N oil filter. Thanks.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Are people taking the side panel right off to avoid oil going everywhere?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I put threaded inserts in where there was rivets. Much easier to take on and off. Pretty slick!
