ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
Oil coming out of bov ..... This can't be good.... Fyi. I have a jet installed in oil line to turbo
and it has run fine with no bleed through the turbo.
.... I just installed a larger bov and now this....any ideas?
Thanks in advance.
Thanks in advance.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Hot supper?
Suggest you do a leakdown test.
Check turbo may have a seal out blowing oil into charge tube.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Yeah that's what I thought.... Boost is also down from 10 lbs to 5 lbs.
I forgot to mention that I also put in black carb springs but I assume they are un related.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Hot supper?
You know rice burner ... The thing I don't like about you sometimes is that you are always right
This time I hope you are wrong but I belive you just confirmed my fear..... Dam.
A new build is not cheap and I just bought my wife a new car...... What is is.
I will never give up my rx.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
Whats coming out of PCV ?
Hopefully Mach is right, not me.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Agreed.... I don't imagine a turbo seal is hard to do.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Well it stopped.... Just like that??? How odd.
Cant change the seals on the center section of a Garrett turbo, it has to be replaced as a whole turbo.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
The oil has stopped coming out. I have an carb jet threaded into the oil feed to reduce the pressure
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Maybe something With the drain line from the turbo?
Plugged but opened up again.
A plugged drain line will cause the same problem as too high oil pressure going into the turbo.
Oil gets forced past the bearings and seals
Oil goes both out the exhaust and into the charge tube.
Have seen both happen.
Glad it fixed itself
