DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
First off I got to say that this site rocks
I have not really posted many messages but this I just got to vent about.
Trying to change my oil in my '05 RX-1, what the
is up with the oil drain plug on bottom of the motor. I can not get the stupid
off.
Any help on this? I have tried using a wrench as a cheater on the allen wrench. Has anyone else had this problem?
off.Any help on this? I have tried using a wrench as a cheater on the allen wrench. Has anyone else had this problem?
Skydog
Yea, they get tight! Hit the head of the bolt with a hammer a few times.
Skydog
Skydog
DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
BIG BLACK WARRIOR
The only way I could get mine out was to get the proper size easy out, and back that out using a wrench. Then I bought a new plug and now, I have no more problems, when I change the oil.
RobX-1
- Coldwater, OH
Well, I must say...after wrestling with the screws on the side panels, oil plug bolt, etc, I think it is pretty evident where retired sumo wrestlers go to get work. They are bolt tightners for Yamaha!
DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
I guess that they must have eaten all there rice that day.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I used a allan head 3/8 socket for my 3/8 drive ratchet. It was snug took a bit of musle.
But above all use the right size. Its metric not standard sized. Don't stip the allen hole.
you should use a hi quality allen socket like a snap-on.i replaced my drain plug before it got too stripped /worn.
Travis Moore
I'm suprised that no one has mentioned the way i did mine...all you need to do is grab the outside of the plug with vicegrips to loosen it. You may ding it a little, as did i, but the sealing surface was fine.
DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
I am now off to Sears to buy a socket and hopefully this will get the job done. Then next is a pair of vise grips. Who knew that changing oil is such a pain.
Hopefully next time this will not be a problem.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
dealer stripped mine for me!!! I replaced it with a bolt of the correct thread size
ptt
Guest
Use a 6mm hex socket.
Skydog
Yea, it is a bad deal very soft!
DK
- Feb 27, 2005
- Logansport, IN
- 2012 Nytro XTX
1998 SRX
1980 Exciter
1988 Sno Scoot
1989 Kitty Cat
Thanks for all the useful input. Hopefully on Friday will have the oil change complete. It would have taken me about 30 minutes if I did not have to screw with that
bolt. Guess I will have to go get another six pack and a couple more hours working in the garage.
