07apexowner
- Jan 12, 2013
Ive got an 07 apex mountain and im getting alot of oil forcing up through the breather tube into the airbox, ive been told about adding too much oil but that isnt the problem, it pukes out oil until the indicator light comes on on the dash and thats within about 10 min of running any thoughts???
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Have you recently had the airbox out? If so, I'd look to see if the tubes connected near the bottom have been reversed. This can cause the problem described.
07apexowner
- Jan 12, 2013
is there a schematic anywhere with the proper routing of those hoses that can be downloaded?
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
I can't come up with one for you at the moment. From my recollection there are pretty much only two hoses that can easily be reversed, so if it were mine, I'd switch them, clean the box, fill the oil and give it a try.
HTH
BTW, welcome to TY!
You will find many, many helpful members ready to happily assist with questions.
HTH
BTW, welcome to TY!
07apexowner
- Jan 12, 2013
thanks for your help, there are two hoses under the airbox but they were hooked up the only way that they can be, one comes from the engine and the other comes from above the throttle bodies and the hoses wouldnt bend around to get crossed. ill keep looking
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Sounds like piston blow-by, which could be caused by a stuck ring. Try some seafoam. Did this just start all of a sudden?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
please post your location per site rules
