My 11 rs venture was leaking oil, it was a loose filter. I could have taken it off with one hand very easily. Tightened it up and no more leaky.
theCATman said:Check your airbox. If it's overfull, it will puke it into the airbox, and then out bellypan.
Oil level should NEVER be over 1/2 way up checkers on dipstick WITH DIPSTICK SCREWED IN.
I'm quoting old information so maybe anyone can answer. My manual for an '05 RX1(I would think it would be the same as the Venture) states to check the oil W/O screwing the dipstick in. Mine is at the full mark. Only rode it once since topping it off and haven't looked for blowing oil yet......... Is that proper procedure?
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Yes.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Well... I'm gonna keep doing it my way. I have changed my own oil on all four of my 4-strokes & the ONE time I filled per manual, it puked into the airbox.
That said, since then it's been carefully add oil until it's on the 1/2 full mark with dipstick screwed in.
IMO, the manual is wrong, just like it's wrong about the fiddle string track tension setting.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
kyzer said:Skid plate is cheap insurance.
X2, have them on both my sleds, and one is a 2 smoke but wouldn't ride either without one.
Skid plate cheap insurance.I have to agree with that one. I had to learn the hard way.
the dealer just refers to it as the oil pan. maybe it is the crank case. Not sure. a new one not to bad at $118 but the only problem is the labor. the whole engine needs to be removed. After checking with a Yamaha dealer they say they cap this repair at 15hr's(most likely will take about 20). So just getting hit hard for labor. I think I learned a lesson. Currently 45 and pouring rain out so not missing too much. The trails are getting hit hard.
