The hose coming off the bottom of the Oil can is driping should this be happening already only 4000 miles any suggestions do i need a new hose?
Best to check it over and make sure it isnt cracked. Change the clamp out it might be stripped. Then make the decision to replace if needed.
Unfortunately things happen.
Clean oil tank bottom for good. Then see if it's coming between halves of tank.
Mine was leaking from there.
Coondog2707
There is a thread authored by Honk, last responded to on October 1, titled 07 Apex GT Oil Leak, that deals with this subject. I experienced it and so did he, both finding the exact same problem. Sounds like you have it too.
Let us know what you find out.
Honk
Yes,Coondog is right,it sounds like the same thing. The elbow was not welded right, and leaks.Looks like they take a piece of pipe and put a 45 % angle on it to make the 90. but doesn't get properly welded. All under warrenty! Best part about it. nice to get something free, once in a while! Good Luck !
