Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Hello All, I am thinking I can remove the oil pan and change the oil pump in the sled. Am I crazy? Thanks.
Not sure why but sure.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Just that it is tight. I looks doable but I might be missing something.
How do you know you have a oil pump failure?
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
With the intermittent shutdown at high speed i suspect the sensor. Based on the code. But possibly a slipping gear as I have seen others describe. Being 8 hours from my snowmobiling destination makes me want to cover all bases. The pump was $210us.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
By process of elimination that would be my last resort for sure if its even possible and even then I probably would pull the motor out to complete that task.. Do let us know if you attempt cause that will be a first I have heard someone doing that…
Definitely keep us informed.With the intermittent shutdown at high speed i suspect the sensor. Based on the code. But possibly a slipping gear as I have seen others describe. Being 8 hours from my snowmobiling destination makes me want to cover all bases. The pump was $210us.
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
My buddy expirenced alot of the same symptoms you have described after a very cold start up one morning. Long story shot we verified 0 oil psi with manual gauge. It ended up being the oil pump drive socket randomly spinning on pump shaft (hence having occasional psi). The sprocket and pump shaft have a matching "D" shape that can round out usually the after a very cold start up. This scenario is pretty rare but I have seen it first hand. The pump can be changed with engine in chassis (with lower body panels removed) but is still a pain in the a$$.With the intermittent shutdown at high speed i suspect the sensor. Based on the code. But possibly a slipping gear as I have seen others describe. Being 8 hours from my snowmobiling destination makes me want to cover all bases. The pump was $210us.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Thanks so much.My buddy expirenced alot of the same symptoms you have described after a very cold start up one morning. Long story shot we verified 0 oil psi with manual gauge. It ended up being the oil pump drive socket randomly spinning on pump shaft (hence having occasional psi). The sprocket and pump shaft have a matching "D" shape that can round out usually the after a very cold start up. This scenario is pretty rare but I have seen it first hand. The pump can be changed with engine in chassis (with lower body panels removed) but is still a pain in the a$$.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Pain in the #*$&@ is not even close to this nightmare. You have to unbolt the pan. And unbolt the pump before you could even think of getting it out. Then take out the 2 front motor mount bolts along with taking the bolts out of the front motor mount frame to slide it forward. Then take a 2x4 and lift the motor to barely get it out. Next I have to scrape the old gasket and reassemble. I will report back when done.
Turboflash
- Mar 18, 2019
- Southern MN
I would have pulled engine and replaced chain while I was in there.
SPM
- Nov 18, 2018
- so. mn
Yep, sounds familiar....that's why I warned ya.Pain in the #*$&@ is not even close to this nightmare. You have to unbolt the pan. And unbolt the pump before you could even think of getting it out. Then take out the 2 front motor mount bolts along with taking the bolts out of the front motor mount frame to slide it forward. Then take a 2x4 and lift the motor to barely get it out. Next I have to scrape the old gasket and reassemble. I will report back when done.
Did you notice if the drive sprocket was spinning on the pump shaft??
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
It was tight with no sign of spinning.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I helped with oil pump replacement, let's say it was a big learning experience. In the end the pump was not the issue or either sensor that was replaced. I wanted to bring this TTT so spaceman can update everyone on what the real problem ended up being.
