iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
how come noo recall
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Recalls are for safety related issues.
Service bulletins are for other problems that yamaha deems sigificant enough to address.
You wont ever see a recall for this issue.
You might see a service bulletin but i strongly doubt it.
Mountaintech
Could you please edit the title of your thread and remove the F word? Feel your frustration but.......
iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
Srry for f word but is there a fix for it or no
I cleaned up title. Sounds like fix is the MPI kit which reroutes it. Check MPI site.
How cold is it up there now? After last time did you clean that box?
iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
How do u clean it
Just remove box and spray brakeclean or even dish soap and water. Goal is to get any oil residue out which holds moisture. Then get it dry. Is a checkball in there that can stick.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I agree. This wont fix the frozen air box but at least with MPI's bypass kit you wont push all the oil out with crank case pressure after the hose is rerouted.
yamahaguy
Ride SAFE
- Apr 20, 2014
Just a few drops of frozen water is what starts all this if the first place, so cleaning with water/soap might not be the best idea? Might be best to clean with something that displaces water like wd-40 or even dry gas additive.
Yes. That's why I said get it dry. Kinda worry about any chemicals wrecking it. WD sounds like a good alternative. That surely would not hurt anything. Good suggestion.
allyammies
We all get pissed its okay!
Yea surely do! Just can't swear here. Definitely felt his frustration though.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Guys,
It is very important to keep the separator box clean to help prevent it from freezing even if you have the separator drain mod done.
During normal engine operation, there is pressure entering the oil tank via the oil pump scavenge line. The pressure is then vented out of the oil tank through the upper vent tube, past the check ball and finally into the air box.
If the check ball in the separator box becomes iced up, that normal venting path is now restricted. With the vent path now restricted the excess pressure is now looking for a new way out via the path of least resistance. On a stock sled where the separator drain is plumbed to the oil tank, the path of least resistance is through the separator drain. The excess pressure then escapes through the separator drain (and in the process pushes oil out with it) and into the air box.
With the separator drain mod, the original separator drain path to the oil tank is capped. Remember even with the separator drain mod there is still pressure entering the oil tank via the oil pump scavenge line. With the original "path of least resistance" capped off, the pressure (from an iced up separator box) has to find another way out or the pressure inside the oil tank will keep building until the point where it either finds/creates new path of least resistance or effects oil pump scavenge flow.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I dint know about this Can some explain what is happening as I'm only guessing hear lol
- 12K
