Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
I think/hope the issue is only on the 18’s. My 17 LTX is dry. The 18 RTX 50th has already been to the dealer at 600kms for a reseal and refill. Nothing since then....
My '17 LTX LE and my buddy's Viper also had leaking (see my Another oil leak thread.)
Hey Dan
A company called CFM Performance in Michigan makes aftermarket tanks for apex's and nytro's - and all sorts of atv's.
I sent them a note to see if this is something they would look into for the Vipers and SW's and will see what they say.
I bet it can be easily done.
MS
I got a tank from them for my '06 Apex RTX after the original developed a leak. Very nice piece of equipment.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Y
Yes way to nice to work on and I replaced the 9rivets with rivet nut insert[/QUOTE
Do you know what size rivet nut insert you used? Thanks.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
6x1.0 mm thread and 1” long did 3 winders now awesome ideal
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Awesome really appreciate the info. So the insert pushes through from back side and bolt must pull it into the hole? I’m attempting to find some today.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
No you a tool to put the insert in I don’t have pics but this is installationAwesome really appreciate the info. So the insert pushes through from back side and bolt must pull it into the hole? I’m attempting to find some today.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I actually think on rockerdans build he has all the information take a lookAwesome really appreciate the info. So the insert pushes through from back side and bolt must pull it into the hole? I’m attempting to find some today.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Dealer gave me yamabond 4 to seal up the tank. It’s the Grey semi drying. I was expecting black. Is the dealer right? Grey is used as a case sealant and those surfaces are machined.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Jaydaniels Ya that’s what cannondale said there techs use at Yamaha dealer as well
Pstn head
I could swear on the fisch it specs Yamabond 6b
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
While 4 MIGHT work, 6 would be preferred.
Sent from my iPad using Tapatalk
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
That’s what I was expecting to get. Hmmm.I could swear on the fisch it specs Yamabond 6b
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Spoke to another dealer today and they use Suzuki 1207B silicone gasket. Said they had better luck with it. Wonder if it compare to the Yamabond 6B?While 4 MIGHT work, 6 would be preferred.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
No experience with that. Could be?
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
I think I’ll just go with the 6b. Thanks for the feedback.No experience with that. Could be?
- Nov 29, 2009
- sabattus, maine
I can’t see yamabond 4 working well. It’s too thin and kinda self levels. You wouldn’t be able to get a good bead and be able to let it tack up.
- 73K
