X2 I will take a pic of tube but if anyone uses it good luck getting if off in future!I would personally go to my local ford or international dealer and get a tube of the sealant used on the 7.3l powerstorke. Stuff is amazing. You need a caulk gun to use. My second option would be right stuff. I’ve done 20+ 7.3 oil pans using the ford sealant. Never had one leak.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
IMPORTANT, SEE NEXT POST!
I know on the DOO the chaincase is only like 8 ft lbs.....So I was abit leary at 12.
I did tighten them down in a pattern starting with 8, then up to 10....then went to 11. But honestly I did not love the feel of it. But specs I read are 12ft lbs. Im sure 10ft lbs is fine.
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
*UPDATED TORQUE SPECS(Oil tank and chaincase bolts)
Ok, now im abit perplexed....
I found another spec sheet, not sure which is correct now....I did like the 8 ft lbs "feel" alot better. I know the DOO specs are around 8 ft lbs.....I would maybe go with the average......10 ft lbs instead, now that Ive got two damn spec sheet that differ. GRRRR
Dan
Spec sheet
Spec sheet
Dan
Spec sheet
Spec sheet
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Please see my previous post....Thanks Dan and no somehow I missed your tq Specs. I'm suprised that it's 12ft points, seems like a lot for that. I would have thought it would have been an inch pound measurement.
thanks
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just added pics to build thread of entire process w/lots of pics....
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-30#post-1442496
Dan
Dan
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
Lol yes getting it apart down the road may be a little tough!! But hey it won’t leak!! Stuff is strong enough to hold the 7.3l oil pan to the block with out any bolts installed. I push the pan up, hold for about 10 seconds then walk away to get bolts lol. Guessing the pan weighs at least 30 pounds. Don’t be scared! It will come apart or leak! Not saying there won’t be some choice words involved when taking it apart thoX2 I will take a pic of tube but if anyone uses it good luck getting if off in future!
Here. Wacker Elastosil A 442
- Apr 14, 2003
- Hessel, Michigan
I use the Permatex Ultra copper.. This stuff works great
I think about any of these work. Watched trained tech do it yesterday and was very surprised to see a huge bead put on. Like 1/4 inch all the way around. Pre tapping if new and then letting it dry well at least overnight are key I guess.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Agree brother....I think its less about type/brand and more about procedure. Does make me wonder why the initial silicone seals all seem to give up(from factory) but most guys seem to say once they have redone theirs, it holds up well. Odd.I think about any of these work. Watched trained tech do it yesterday and was very surprised to see a huge bead put on. Like 1/4 inch all the way around. Pre tapping if new and then letting it dry well at least overnight are key I guess.
I would prefer a thicker silicone, that has much less squeeze out. But I guess most guys do these on the sled, where I did mine on bench. Will see how it goes. I have no reason to fill it with oil for awhile, so Ill wait awhile.
I think the waiting part is a big key. Knowing how factories push things to get done is probably the problem. Seen it before. It basically put Cannondale out of business.Agree brother....I think its less about type/brand and more about procedure. Does make me wonder why the initial silicone seals all seem to give up(from factory) but most guys seem to say once they have redone theirs, it holds up well. Odd.
Bt04f250
- Mar 6, 2017
- IL
Agreed with waiting. I always wait at least over night to fill with oil. Gotta give the sealant a chance to seal and dryI think the waiting part is a big key. Knowing how factories push things to get done is probably the problem. Seen it before. It basically put Cannondale out of business.
cobrajet ltx dx
2 step process
Both machined surfaces must be completely clean with no oily film.
Metal prep cleaner works fantastic.
Makes sure the sealant bonds to the surfaces.
Need to give time for the sealer itself to cure before adding fluids.
Factory’s fall short with that process all the time.
NYTurbo
Don't over due it with too much either , don't want chunks of silicone floating around in there. Seeing some pictures where clearly people went over board.
I would have given same advice before seeing how the Tech did it. They were specifically told to use alot. 1/4in bead. Thats one reason to let it cure well. No floaties.Don't over due it with too much either , don't want chunks of silicone floating around in there. Seeing some pictures where clearly people went over board.
- 10K
