SteelerJim
Has anyone figured out a reliable way to get those suckers out without messing them up? I'm guessing I'll have to sacrifice one for every one I get out.
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
If the arm is bad, put a cut in arm this will release pressure on bushings should tap out then.
Sent from my Nexus 5X using Tapatalk
gmfamily2008
if the arm is junk , unless your looking to powder coat , just cut in half , tap out from the inside .Has anyone figured out a reliable way to get those suckers out without messing them up? I'm guessing I'll have to sacrifice one for every one I get out.
Dr. FeeLGooD
I was surprised how wore mine were when I had to replace an A arm. I bought new bushings.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Look on the bright side of this - if they have been in there for awhile they likely need changing anyway.
Once they have been pressed in, they are so soft, reusing them is marginal even when you can get them out.
Just my ten cents.
MS
Just my ten cents.
MS
- 7K
