rtx moose
- Jul 31, 2014
- WATERTOWN,MN
what size are the bushing id-od- oal end hat dia?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
is this a secret??????????
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
No secret, its just that few would take the time to measure and record the dimensions.is this a secret
Its all about getting the old bushings swapped out with the new one's.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Nope just wondering if it’s a suspension bushing, or upper gear bushing for what sled?is this a secret
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
This is a stronger bushing than the oilite bushing, almost double the load capacity. Lubricated chaincase really doesn’t need an oil impregnated bushing.
Mcmaster #2867T67
Im assume it’s the chaincase bushing for a procross your looking for?
It will require that you remove about .001” of an inch from the inside diameter after being pressed in.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
this is for a arm on my apex
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Do you need dimensions for all of the control arm&spindle bushings?this is for a arm on my apex
