ryan11007
- Feb 3, 2014
What happened to the osp post? Looking for the instructions. U take the 3 sets of washer shims off back of secoundary. But I'm trying to find out. The shims behind the secoundary on the shaft. Do you remove them all and just have the secoundary tight to bearing and circlip?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No do not remove the washer on shaftWhat happened to the osp post? Looking for the instructions. U take the 3 sets of washer shims off back of secoundary. But I'm trying to find out. The shims behind the secoundary on the shaft. Do you remove them all and just have the secoundary tight to bearing and circlip?
Remove the small bolts on back of clutch
rbell14
Right on, 3 small bolts on back of secondary. Use adjuster to set belt deflection then. Heard owner of OSP passed away. Not sure on status of the business so some videos may not be on their site anymore.
rbell14
ryan11007
- Feb 3, 2014
Yea I've seen this but still doesnt tell you or show u the shims on the shaft
QUOTE="rbell14, post: 1397865, member: 18568"]Found a link.
https://www.bing.com/videos/search?...F6D011BDD80BEE16073FF6D011BDD80BE&FORM=VRDGAR[/QUOTE]
ryan11007
- Feb 3, 2014
Want to know about the shims against the bearingRight on, 3 small bolts on back of secondary. Use adjuster to set belt deflection then. Heard owner of OSP passed away. Not sure on status of the business so some videos may not be on their site anymore.
rbell14
Shims on your bearing have nothing to do with adding the adjuster. The only parts you remove are the 3 screws on back side of secondary shown in video.
rbell14
Same adjuster from different company with instructions...
https://excellmotorsports.stores.dealerspike.com/product.aspx?zpid=6619913
ryan11007
- Feb 3, 2014
Yea when I changed my bearing I think I might of lost the washer or shim. All I see is circlip and bearing.Shims on your bearing have nothing to do with adding the adjuster. The only parts you remove are the 3 screws on back side of secondary shown in video.
If look in the Tech section of site the clutch offset and how to measure it is there. It’s pretty easy to do. I have never seen one without the washer but different thicknesses are offered.Yea when I changed my bearing I think I might of lost the washer or shim. All I see is circlip and bearing.
ryan11007
- Feb 3, 2014
yea turns out some dont have them and looks like mine is just to say in spec with no washer. thanksIf look in the Tech section of site the clutch offset and how to measure it is there. It’s pretty easy to do. I have never seen one without the washer but different thicknesses are offered.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've never seen one yet without a washer. I know they can stick to the secondary when it's removed and forgot about when reassembling.
