2stroken
Should the ball move in the spindle, or do you tighten the bolt tight enough to hold the ball from moving?
It never will be tight enough to stop moving unless something is wrong. Use Loctite on bolt and get it tight.
2stroken
So I assumed that cranking down on the bolt would push the spindle tabs together and not allow the ball to rotate in the spindle(which I don't see as an issue as the ball can still rotate in the socket). You are saying no matter how tight I tighten the bolt, the tabs on the spindle will never squeeze enough on the ball to keep the ball from moving back and forth in the spindle?It never will be tight enough to stop moving unless something is wrong. Use Loctite on bolt and get it tight.
Mountaintech
The spindle webs should tighten down on the ball flanges.
2stroken
Thanks, that was my understanding, had one on the venture lite that was loose.The spindle webs should tighten down on the ball flanges.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
IIRC, isn't there a couple of small washers top and bottom of it? Maybe one is missing.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Yes, make sure the washers are there! I have to actually use a flat screw driver to push the 2nd small washer in as it’s a pretty tight fit on mine. It’s very easy to loose one of the small washers when taking it apart if you don’t know they are there.IIRC, isn't there a couple of small washers top and bottom of it? Maybe one is missing.
