TrueBlue
I have a 2018 Vector & yesterday while I was adjusting track alignment & tension I guess it got pretty hot & started leaking anti -freeze .(quite a bit) It seem to be dripping down & around the area of the front heat exchanger. What I would like to know is there a over flow hose it could be leaking from when it get's that hot.
Yes, it will piss out the over flow when you get the motor to hot.. how long did you have it running in this 80 degree weather?
TrueBlue
Around 20 minute's or so
that would do it!!
TrueBlue
that would do it!!
Do you think I have done any damage. Will I have to re-bleed the system or can I just add anti-freeze little by little with engine running.
im sure it’s fine. Just top it off and top off jug
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Like Tom said these sleds over flow when hot.
TrueBlue
When you say just top it off & top off jug are you talking about the coolant recovery container & the coolant reservoir container. I figure I lost at least 2 quarts of anti-freeze. When I buy the anti-freeze from Yamaha does it matter if it is green or blue. I know they changed the color & does it matter if I mixed them. Because it got so hot do you thing I did any damage to the water pump or the impeller. When I was adjusting the track from behind I didn't notice the anti-freeze leaking.
Thank's in advance Tom
If you lost 2 quarts, I cant say for sure. All you can do is refill the entire system and hope for the best. I have mixed them and had no issues.
it does not take much to look like you lost a lot. probably puked out 1l of antifreeze from heat as that is what my phazer did with an ice dam covering the front cooler in 2' of powder when i shut it down for the heat light. been fine since.
- 41K
