FOURSKIN
can i buy a pc5 and plug in a ignition module that use too work with a pc111 i did here that the ignition module will do nothing ... do i have to stick with a pc111 i would like too by the latest pc . this is for 2006 apex
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If you go with a PC5 there currently isn't an ignition box available that is compatible with the PC5.
If you want the ignition module then you have to run the PC3.
FOURSKIN
DO YOU THING IT WILL BE AWHILE BEFORE IGNITION MODULE IS OUT AND WILL IT WORK FOR 2006 OR ONLY THE NEW 2009 DO YOU THINK ITS WORTH THE WAIT BECAUSE OF THE EXTRASOF THE PC5 WHICH OFFERS ADDITIONAL MAPS ON THE FLY .I HAVE ONLY RAM AIR FOR NOW . WOULD LIKE TO DO THIS AND MAYBE A YAMMA CHARGER NEXT YEAR .
- Apr 17, 2003
- Menno, SD
- Menno, SD
I have no known date for when the Ignition Module for the PC5 will be available. The PC5 will work on any year Apex.
