Phazer FX fan, radiator guard and tunnel closure
Cincinnati
Here's some mods to my FX.
Excellent job!!! That is the nicest rad job I have seen so far, a whole lot better than gutter guard. This fall I will be looking for this when I get mine, so could you make up a hand sketch in advance and e-mail it to me??? How much is the fan?? If you don't mind me asking. Thanks and once again great job. Morgan.
My ride
Here's a couple of pictures of my ride.
Nice looking job. Have you got much time on it since you closed off tunnel and did you close off both holes? Any overheating problems under the seat? Did you wrap the exhaust with any heat tape or anything?
I have 350 miles on the mods with no problems at all. Only the rear hole is closed, but I plan on doing the front as well. I will wrap the front exhaust with motorcycle heat tape. The perforated grill guard is stainless steel from onlinemetals.com.
Nice lookin job on the rad cover... Nice lookin ride as well!
Have you tried it yet? Wondering if it clogs with powder?
Why bother to cover the whole rad when only the top portion is open to the elements?
I've gotta do a cover for my sled during the off season!
Holes do look a little small, but this is the nicest cover I've seen so far.
5 ski tips out of 5 .... kewl
Nice job FLYBOY, same stuff I used but mine is aluminum. Here's a picture of mine for those who want to keep snow and ice from forming in the side panel. I have a Mountain Lite and never have had a problem with it clogging or overheating but it does have the fan on it. Air flow through that perferated screen 78%, I have 1000 miles on since install works great and no fear of the sticks or anything else.
OST: No, I have not tried it in deep power. The guard is held about 1/2" from the face of radiator and with the fan it should suck air in from around the sides of the perforated face should it clog. I covered the entire grill because the mounting bolt I used to attach the guard on the front of the radiator is down so low. It would have been harder to construct a partial cover, although possible. I just wanted to protect the entire radiator face. My design is removable with no alteration to the sled.
Upbushman: Nice design too! I considered your design also because it protects every square inch of the radiator. I didn't think I could make the complex bends to fit as well as you did. Your design is what should have come from the factory along with the fan on all models. With the fan, the sled can idle all day with no problems. You may not need that feature until the one day you almost didn't get the sled running and now you're stuck and the thing is starting to overheat. Do I shut it down with no restart or do I chance damaging the motor?
