TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
found my answer and ordered this kit
Gone Blue
- Oct 11, 2006
- Howell, Michigan
This inner tie rod bearing kit helps a lot. I installed this kit, plus OFT steering blocks, and UPBushmans spindle kit on my 09' Phazer and the steering on my sled has never been so tight and slop free! G.B.View attachment 134308 whats the best kit out there to tighten up the steering slip on a 2007 gt? I found this heavy duty bearing kit on Yamaha website anyone try it? Also the tie rod ends in the spindles those bolts are sure loose. I tried searching but found little info on this kit.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Yeah the steering block is slopped out to. Thanks for the reply.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Could you let me know how the kit works?
I looked at it two years ago but my dealers mechanic didn’t think much of it so I never bothered to order it.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Forsure. I bought a used gt and the steering is very sloppy around that area where these bearings go. So I’m thinking it will do nothing but good. Will post when I get it installed.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Also noticed that the inner tie rod ends are bent along with the steering rods. Anyone have luck straightening the rods? Just a slight tweak on the end of each one. Tie rod ends are garbage.
shockwave
- Feb 25, 2010
- St Paul d'abbotsford Québec
- 09 Phazer RTX
Do y
Do you have the part number? My next summer upgrade.
Creeksider
- Nov 16, 2014
- Kemptville Ont.
- 2010 Yamaha Phazer
I installed the Yamaslop factory upgrade. It seems to have taken out about 50% of the play. Passing the bolt through one of them was a major PITA, not something I'd do again.
The golden rule of striking the outer race of a bearing to seat it does NOT apply to the above pictured OEM kit. I figured it out after the 3rd-4th hit. I slightly damaged it but not enough to justify a replacement. It'll never do a full rotation anyways.
Creeksider
- Nov 16, 2014
- Kemptville Ont.
If you take them to a machine shop, they can press them straight again. I fixed a few rods this way.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
I just installed this kit and put 400km on it now. No change in sloppy steering. 12k on dial.
MikeWalters
That kit is OK, but does not address the vertical play the steering has.
Watch this vid (after 500km put on). I added some machine bushings to take up some of the vertical slop, but seriously the UPBushman kit is the only one that delivers. Not sure if he's around anymore, been a long time since he blew up his engine and went to a Polaris.
shockwave
- Feb 25, 2010
- 09 Phazer RTX
He is still around. He sent me some UPBushmans spindle kits in December.
ATV PRO #11
- Jan 22, 2011
Was a pain to do that kit. Had to file down rough edges on new machines pieces to slide my stock bushing in. To be honest, aggressive rider here, I truely don’t notice the play in any trail conditions.
Gerrit
Hi Shockwave, would you have contact info for UP bushman or did you just contact through the site here?He is still around. He sent me some UPBushmans spindle kits in December.
- 6K
- 113K
