Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
07 Attak, Want to get a pivot adaptor so I can use adjustable risers, but I definitely want to keep the stock chrome trim, and from what ive rear the only ones that allow that were the lake effect and muffin works ones, who are no longer in business. anyone know of any alternatives? maybe the TXR? cant find info on it...
I would still contact Chris at lake effect, he still has stock.
dmaxx
- Apr 5, 2006
- sw Michigan
- 2015 Viper RTX, 2012 Apex XTX, 2010 Vector LTX, 2000 AC Z-370..fast
- White Pigeon, MI
I used a Rox adjustable riser on my Attak, used a flat pivot adapter with a riser that cleared the trim ring.07 Attak, Want to get a pivot adaptor so I can use adjustable risers, but I definitely want to keep the stock chrome trim, and from what ive rear the only ones that allow that were the lake effect and muffin works ones, who are no longer in business. anyone know of any alternatives? maybe the TXR? cant find info on it...
Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
Do you know what brand adapter you used?I used a Rox adjustable riser on my Attak, used a flat pivot adapter with a riser that cleared the trim ring.
dmaxx
- Apr 5, 2006
- sw Michigan
- White Pigeon, MI
Powermadd. I can set you up with a package if you wish as I carry those products. Shoot me a message.Do you know what brand adapter you used?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
X2 on the PowerMadd Pivot. Worked on two apex with the stock riser. It gave me an extra 2.5" and didn't need new cables.
Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
You have the powermadd adapter mounted at the base correct? And the rox adjustable on top of that? I have seen people use the pivot adapter on top of the stock riser and I just want to clarify. Any photos of your setup?Do you know what brand adapter you used?
dmaxx
- Apr 5, 2006
- sw Michigan
- White Pigeon, MI
Yes, Rox on top. I don't have that sled anymore and don't have a pic. I also have a Rox 2" on top of my stock riser on my XTX cause it was a simple app.You have the powermadd adapter mounted at the base correct? And the rox adjustable on top of that? I have seen people use the pivot adapter on top of the stock riser and I just want to clarify. Any photos of your setup?
