Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
As of this moment I have a splitter from Artic Cat / Yamaha plugged in it allowed me to power up heated seat and heated visor ! Artic Cat dealer says heated seat instructions say to use that plug for heated seat ! Is it too much juice to have between heated seat and visor to that one plug which is NOW Split ?
I know I could use 12 volt plug !
I just installed dash mount !
I'm not looking at other accessorie after market outlets Now, looking to see if I like how this 2016 XTX SE 141 Drives before I sink any money into it !
Tha is in advance !
Tha is in advance !
It will be fine. You will like the heated seat.
klondike22
I have the ac splitter there also....no issues....heated seat and face shield power seems fine.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
ok my ? is if i buy the acc plug from yam is there already a spot on the harness under the panel..i see the 2018 50th has the plug as standard...or does it plug into the one your talking about?
yamaha4sea_fan24
- Jul 30, 2018
- Townsend, WI
- 2018 Yamaha Viper RTX
2018 Yamaha Viper RTX - Wife's Sled
- Townsend, WI
Where is this accessory plug located, isn't it somewhere near the chaincase? Can it be accessed if you take the hood off without removing the exhaust? I'm looking to add the Arctic Cat heated shield plug that would've come standard on the LTX model sleds...
tsiceman
It is right there by reverse actuator.
yamaha4sea_fan24
- Jul 30, 2018
- Townsend, WI
- Townsend, WI
Thank you, will be installing new heated shield plug next weekend!It is right there by reverse actuator.
