str8motard
just got my pcv from ulmer today and im unclear where I mount the map sensor. I saw some people mount it on intercooler but really don't wanna pull it back off, charge pipe ok? im running a custom 2554 rear mount at sea level
kennyspec
I believe that most people mount it in the intercooler. if you do put it in the chargepipe I would assume you would want to put it post cooler. this way it will read accurate air temps that are entering the engine. If you were to tee it off of one of the factory map sensors you could also tune when the sled is in vacuum.
str8motard
Correct me if I'm wrong but doesn't that map only read air pressure?
kennyspec
The factory map only reads pressure but i believe that the pcv map is a tmap meaning it can read temperature and pressure.
- 148K
- 32K
