snolover
- Dec 1, 2004
Allen i just finish install a powerband (koso) and i read 13.4 to13.7 on the meter do you think i am running lean
i got a ram air kit (fix motor sport) also i have excell muffler
my question is do i need power com.v and do you do the mapping
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
What sled are you running on? Apex I assume? You will have better power at 12.8 on your wideband gauge.
snolover
- Dec 1, 2004
Yes im running apex 08 you think a power com.v will help
thank
thank
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes you will get more top end power by lowering the top end air/fuel ratio.
Weapon X
Well would it work better or worse if you had the schmidt bros fuel regulator on your sled?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Weapon X said:Well would it work better or worse if you had the schmidt bros fuel regulator on your sled?
As far as I know Schmidt bros only makes the fuel regulator for the Phazer models. I have not tried one, but I am sure the Power Commander would work with it, just would require a different setup on the map.
