baknblk
Anyone running the Power Commander & Ignition Module with Nitrous ? If so, can you run at stock rpm's (high 10's) or do you still have to clutch down?
rapeape
- Jan 8, 2006
- Brookville, PA
- campkevin.com
Bump
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Yup, I run 11500rpm on nitrous now!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You must do the Rev Xtends to get the higher RPM rev limiter.
