mr rxl
This question has probably been asked before. What fuel is everyone using?
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
89 when not on the bottle.
93 when on the bottle.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
87, compression isn't high enough to warrant any higher octane.
dealer told me 87 always, 91 burns too slow they told me.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
87 here.
STS
I use 87 myself, I believe that SrxSpec posted results from a dyno test that showed a loss in power with the higher octane fuel.
Owners manual calls for 86 or higher. If I could find 86, I'd buy it. Cheapest I can find is 87 so that's what it runs.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
86 octane is available in Japan, so that's why the manual says 86 or higher. 87 is what I use and works just fine. Don't waste your money on the higher octane gas.
mr rxl
Thanks. Great site.
SharkAttak
87 with ethanol (as they have here in MN) won't harm the engine?
bashley
SRS was right about higher octanes burning slower. 87 burns faster but 89+ burns longer and more complete. This causes more deposit build up over time with the 87. Use a decent fuel injector cleaner on a regular basis, just like your car/truck.
Same performance and cleanliness. Cheaper in the long run than buying premium too.
SRXSRULE
85 ocatne baby! Runs much, much better then if I have to fill up with 89. Sometimes I have to get gas from the lodge on the mountain and they carry 93 for all the 2-smokes! Makes my sled a dog. Eric
bigbigrichie
why does it say 91 or something different on the side of the sled?
The Better Gas Will Run Better. Like all fuel injection systems Timing Changes are made when running better gas.. elevation ..engine temp ping Knock etc...87 should be the minimal octane rating for this type of high performance engine
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
bigbigrichie said:why does it say 91 or something different on the side of the sled?
87 here you will loose HP running premium,Mine doesn't say 91 on the sled, and I have never saw one that does!! Are you sure you have an Apex?
