Gone Blue
- Oct 11, 2006
- Howell, Michigan
As I have now almost 8,500 miles on my 08' Nytro, I think I want to rebuild or freshen the clutches this summer. I have read thru most of the clutch posts on here and cant seem to find a list of parts that should be replaced when going thru higher mileage clutches? I want to use Yamaha parts as I am not a fan of SPI stuff. Thx G.B.
CLUTC TUNE-UP KIT
8FA-W176H-10-00
for the primary from yamaha.
for the major rebuild kit,
CLUTCH REPAIR KIT
8ES-W176G-12-00 (replaces 8ES-W176G-11-00). i do reccomend new springs as that is usually a good part of any performance losses.
as to the secondary, probably only needs 3 new ramp shoes and maybe a new spring. ramp shoes are
SHOE, RAMP
8AV-17688-10-00.
8FA-W176H-10-00
CLUTCH REPAIR KIT
SHOE, RAMP
8AV-17688-10-00.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Thanks Maim. I remember seeing these kits in the micro fiche but couldn't find them today on Port Yamaha's site. G.B.CLUTC TUNE-UP KIT
8FA-W176H-10-00
CLUTCH REPAIR KIT
SHOE, RAMP
8AV-17688-10-00.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
Does the #8ES-W176G-12-00 CLUTCH REPAIR KIT normally come assembled or disassembled (spider & movable sheave not assembled yet)?CLUTC TUNE-UP KIT
8FA-W176H-10-00
CLUTCH REPAIR KIT
SHOE, RAMP
8AV-17688-10-00.
it is all the bushings/rollers to rebuild your clutch. you have to disassemble your clutch and remove the spider to put all the bushings in.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
No, the 8ES-W176G-12-00 CLUTCH REPAIR KIT is pretty much an unloaded clutch without weights, spring, or rollers. You are thinking of theit is all the bushings/rollers to rebuild your clutch. you have to disassemble your clutch and remove the spider to put all the bushings in.
CLUTCH TUNE-UP KIT #8FA-W176H-10-00. I have purchased one of the CLUTCH REPAIR KITS in the past a while back and it was assembled when I got it but I am seeing some posts here and there that other people have received a box of all the parts and had to fully assemble the clutch themselves.
05rx1204
Are the kits from spi that bad? I'm usually an oem guy. But here in Canada the yamaha maintenance kit is 400$ from the dealership. I can get an SPI kit for 90.
idk for sure. have had to lock tight bushings into clutches as the replacements do not always hold. make sure everything slides freely before putting the springs in and into service.
Franky98
About de sheave.CLUTC TUNE-UP KIT
8FA-W176H-10-00
CLUTCH REPAIR KIT
SHOE, RAMP
8AV-17688-10-00.
Franky98
About the sheave?
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I decided to send both clutches to Chris Schmidt and had him rebuild them this past August after they had 10.500 miles on them. So I am good to go for this season and many more. GB
