69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
Woody255
Lucky you didn’t get hurt! Both sheaves broken of just the moveable? I’ve never seen them break that bad....
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Damn.....seems like more and more clutches coming apart.
How much HP/tune?
Dan
How much HP/tune?
Dan
69redmach!
- Nov 27, 2016
- Loudon
Outside of secondary only. Chunk missing. Never blew the belt and the belly pan was unscathed. Everything came out the top
69redmach!
- Nov 27, 2016
- Loudon
Evo 260 tune. I've never blown a belt and rarely did top end runs.
EEvvoEvDamn.....seems like more and more clutches coming apart.
How much HP/tune?
Switching over to a TEAM is more and more on my mind.
Dan
@123
what running rpms when it happens?Outside of secondary only. Chunk missing. Never blew the belt and the belly pan was unscathed. Everything came out the top
Byam
You probably had destroyed roller and the weight pass trough ..:-(. Sad!!!! Not the first time i see this
Our clutch need a lot of attention......
Wingwong
- Mar 20, 2018
Did you have stock clutch arms or did you install aftermarket. ? Do you know what weight you were running and what RPM did It happen at? Very sorry for your misshap
69redmach!
- Nov 27, 2016
- Loudon
9100 rpms. I had installed the complete clutch kit last year including rollers and arms. Probably had 2500 miles on this. I do mostly high mile trail rides. It was running well up until this point.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'd guess thats the problem here. Worn rollers and those shorter than most, Heavy Hitters rolled right past the worn out rollers and bang, ripped them right out of the clutch as it was fully shifted out. Every one I've seen broke has had these HH weights in them.
The clutch did not completely explode though, which is good. I don't see this as a Yamaha clutch problem, other than the worn out bushings. The HH arms are just shorter than they probably should be. Fine with good rollers, but worn out bushings and they roll right off the roller. Set them side by side with most any other brand weight and you'll see how much shorter they are.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I did not like those HHs for setup either.....Daltons for me ever since.I'd guess thats the problem here. Worn rollers and those shorter than most, Heavy Hitters rolled right past the worn out rollers and bang, ripped them right out of the clutch as it was fully shifted out. Every one I've seen broke has had these HH weights in them.
Good to know Mike!
Dan
@123
really ok i though maybe it was higher rpm but 9100 is good that’s weird9100 rpms. I had installed the complete clutch kit last year including rollers and arms. Probably had 2500 miles on this. I do mostly high mile trail rides. It was running well up until this point.
69redmach!
- Nov 27, 2016
- Loudon
Thanks for the tips guys.
- Nov 29, 2009
- sabattus, maine
Wow, glad you weren't hurt. Sleds can be fixed.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Man you are one lucky man,wow that's bad,i wonder what yamaha is going to say to this?? What tune you running,and any idea roughly what PSI motor was at when this happened.7300 miles. Thunder Racing clutch kit. I was doing 120 mph across a lake and this happened. Debris broke my secondary too and air box and hood. Pieces went right through my upper clutch guard.
