thetruck454
Nytro has just under 11k on it. I'm assuming that wear on the primary shaft is normal, but when should I replace the bushings/spider rubbers? I'm on my second clutch kit so springs and rollers/weights are fresh(ish). I've also replaced the buttons/spring on the secondary recently.
When is the last time you replaces the spider guides?Nytro has just under 11k on it. I'm assuming that wear on the primary shaft is normal, but when should I replace the bushings/spider rubbers? I'm on my second clutch kit so springs and rollers/weights are fresh(ish). I've also replaced the buttons/spring on the secondary recently.
thetruck454
I bought the sled new and have never changed emWhen is the last time you replaces the spider guides?
Then it wont hurt to change them.I bought the sled new and have never changed em
