Tork
Buckeye said:I'm wondering if something isn't in the hole also. The bolt is 1/2" x 20, which is also something metric.
Yeah Buckeye, I did have the metric size figured out, but no industrial supply in the northern 1/3 of WI had one. My dealer told me to use the 1/2
(and I think you are right) x 20 as that is what he uses. Those were easily available from a number of sources.
LazyBastard
The clutch will have seated, BUT, with that much force holding into it, the *SUDDEN* release of the bolt holding it on will cause the clutch to back off a bit, sometimes even to fly off.
RX-1 Touring Freak
Often manuals are not 100% correct do not be to hard on yourself thank god it broke then and not later at 8,000rpm !!!!!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
broken bolt
How you doing cowboy,heck i used to go by my book on my 03 at first,than i had it on/off so much that i just torqued it on with my torque gun,and never had a problem,good luck.
