Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hey guys. What can I do to clean up primary rollers while on the sled & which way should I rotate clutch???
Please don't ask....... forgiveness is true love. Lol..
Merry Christmas.......
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Rotate in forward direction only.
Maybe lightly sand the rollers with some emery cloth or green pad should work.
Doc Harley
- Oct 17, 2016
- Here & there
So counterclockwise? Thanks.....can I call you OCD Dan...is that wrong? You're the best. Merry Christmas buddy....
NYTurbo
Counter clockwise only.
Byam
You better remove them for inspection!
It take 2 minutes to do whit clutch on the sled 8mm 8mm and its done! Make sure which way they rotate before removing them and chek for bushing "slip" clockwise ;-)
Doc Harley
- Oct 17, 2016
- Here & there
Byam, bushing goes back in exactly the way it came out. Rotating in same direction?
Bushing slip?? How do I check for that?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Easy way to remind yourself is.....which way does the clutch turn for thousands upon thousands of miles? Just common sense to be sure to turn it that same way. lolSo counterclockwise? Thanks.....can I call you OCD Dan...is that wrong? You're the best. Merry Christmas buddy....
Dan
