ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Starting to get my parts together for fall maintenance. And want to replace the primary rollers , before they cause problems. Is the general consensus , aftermarket.....or OEM being the better roller.
HURRICANE
We keep thundershift rollers instock because the quality is good
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Thunder for me too....
Did much better then stock.
Fast
- Sep 25, 2018
Best thing to do is remove them and measure the wear to see if they are within tolerance before replacingStarting to get my parts together for fall maintenance. And want to replace the primary rollers , before they cause problems. Is the general consensus , aftermarket.....or OEM being the better roller.
NYTurbo
just replace them with a quality roller, like Thunder products that Hurricane sells.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
15.5mm rollers from a viper clutch. 7000+kms at 270+hp on mine.
Fast
- Sep 25, 2018
1500 miles 2019 srx and mine are still like newjust replace them with a quality roller, like Thunder products that Hurricane sells.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
5500 miles on my originals and they still look good. I do a quick check of my primary rollers after each ride, and did take them out for inspection at 5000 miles because of all the problems noted with them on this site.
Mine have been a bit loose since day one, when compared to other Yamahas that I have owned, but each time I tear it apart for inspection all bushings are perfectly round and show no new wear yet.
EcoTrail tune and then upgraded to Max Spool 16 tune 3000 miles ago. Also tried a primary clutch kit, but went back to stock ramps with added weight for lower engagement and more consistent WOT rpm.
Maybe they are lasting because I do not use studs (1.22 Ice Attack w/ 268? Or so Pre studded)
Not sure why mine are lasting, but I will say that this thing rocks on the trails. Low engagement makes for less track spin out of the hole and after 10-15 ‘ that track is hooked, With exception to ice of course!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Dennis,you still stock secondary everything? What was your engagement with the Dalton ramps and what primary spring did you run with his ramps?5500 miles on my originals and they still look good. I do a quick check of my primary rollers after each ride, and did take them out for inspection at 5000 miles because of all the problems noted with them on this site.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Woody had my clutches machined with my first Eco trail tune, along with his moddded stock muffler back in beginning of 2018 season.
Primary faces machined so that the belt will use all but an 1/8”. Secondary coil pocket machined .070
Engagement with Dalton and Yamaha Blue/Brown spring was 3200, a bit higher with stock primary spring.
Now at 2800 cold, and a bit lower after clutches get warmed up with the stock ramps with weight added.
Did not want to spend anymore for part testing, so I used what I had, and it works really sweet. Retiree budget.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ha ha I like that retiree budget idea too,lol.Woody had my clutches machined with my first Eco trail tune, along with his moddded stock muffler back in beginning of 2018 season.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Keep an eye on your rollers even if running aftermarket ones. The bushings were shot in mine at 1800 miles when I checked them. I picked them up at the Milwaukee snow show last fall.
Mototown
If you are a do it yourself guy ... These replaceable Yamaha duralon bushings last very well in the original Yamaha rollers ( and you get to use the 14.5 mm roller) . The biggest problem I have found is the stock bushings move in the roller binding the roller, then u are only a couple hundred miles from disaster with weights going past the roller destroying clutch.These fit much tighter than the original bushings.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I just tore my clutches down and my stock primary rollers at 10000 Kms still look ok in my books... The bushings all look good, no uneven wear, the bushings haven't moved out of the rollers. Compared to a set of Nytro rollers I have I cant tell the difference. Not sure if I should replace them or not. I've been tuned for 9000 Kms.
race24x
Wondering which Thunder products are the correct ones for my Sidewinder. I see there are 2 sizes 14. something and 15. something. How do I know which ones to order
