SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Stain, any news on your bronze bushing testing? Or did I miss it. I've been thinking of trying this also.I am testing some bronze bushings in the primary rollers right now I will see how they last
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
So far so good. I have close to 900 miles on them with no noticeable wear.
SPM
- Nov 18, 2018
- so. mn
Did you use oilite bronze material?how much press fit in the wheel?Clearance on pin?So far so good. I have close to 900 miles on them with no noticeable wear.
Thanks for the info!!
What about the Helix?So far so good. I have close to 900 miles on them with no noticeable wear.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
They are primary rollers. Just the bushings and washers. I bought the bushings from G-force and pressed them into whatever roller size I am using.What about the Helix?
Ok so what about the clutch surface?They are primary rollers. Just the bushings and washers. I bought the bushings from G-force and pressed them into whatever roller size I am using.
Didnt want to step on Mikes toes so starting a new thread here.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The pin, i have not pulled it out yet to check. There is no excessive movement in the roller while on the clutch. I will pull one off tonight and check.Where the roller rides on.
I am this close to buying a TAPP
Not the pin. The aluminum slot the roller rides in.The pin, i have not pulled it out yet to check. There is no excessive movement in the roller while on the clutch. I will pull one off tonight and check.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
no wear there either yet. i do have access to magna-flux system. i might try it on this areaNot the pin. The aluminum slot the roller rides in.
Cool very good sign. Nice job!no wear there either yet. i do have access to magna-flux system. i might try it on this area
@123
does it change your rpm? and did you lost performance?no wear there either yet. i do have access to magna-flux system. i might try it on this area
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Not sure what you mean by that...does it change your rpm? and did you lost performance?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Here are pictures of the bronze roller bushings after @900 miles. Still tight. They seem to be oilite as there is some substance on the bushing but it does not seem to hinder performance. These bushings are not run of the mill bronze bushings. They are actually bigger on the thrust side as not to be pushed out by the rotational force. The shims are also cut to fit the bigger size of the rotational end. The bushings and the shims are matched.
While I was at it I magna-fluxed my clutch to check for cracks. Happy to say am crack free!!!
