scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
I have a 2017 sidewinder 137 that has a turbo dynamics 250 flash,, dalton black/ orange secondary spring and dalton weights on the primary. I broke the Yamaha gold/ red/ gold primary spring and it seems to be rubbing on the stock clutch hub. I’ve read about using thunder products glide washers . So I think I’m going to try those but I want to try a different primary spring. Reading forums the opinions seem to be spread out. Didn’t know what people would recommend. I think I’m fine with a stock type rpm engagement… I make more high speed passes than I do drag race style launches. Thanks
scottt
- Jan 30, 2018
- maine
Reading more it sounds like the dalton red/ black or the TP orange,,,, sound about right?I have a 2017 sidewinder 137 that has a turbo dynamics 250 flash,, dalton black/ orange secondary spring and dalton weights on the primary. I broke the Yamaha gold/ red/ gold primary spring and it seems to be rubbing on the stock clutch hub. I’ve read about using thunder products glide washers . So I think I’m going to try those but I want to try a different primary spring. Reading forums the opinions seem to be spread out. Didn’t know what people would recommend. I think I’m fine with a stock type rpm engagement… I make more high speed passes than I do drag race style launches. Thanks
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I use the Dalton red/black on my 240 tune and seems to work fine.
Fords4life
- Dec 7, 2021
- South Dakota
If you are getting thunder glide washers talk to terry or tim they will point you in the right direction, realy great guys to work with.
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
I use the glide washers and a ppp Yamaha spring in primary with Dalton weights, lowers your engagement and smooths moving the sled around, works very well from 240-300hp for me.
