- Apr 14, 2003
- Hessel, Michigan
Congratulations to Kurt Schultz this past weekend 4/20/19 winning the #1 spot in Pro Stock 800 at the Mid Michigan Motorplex in Stanton, Michigan!!!! Kurt uses Thunder Products Clutching TSK adjustable weights in his Polaris to put the power down to the ground.
MSADRA (Michigan Snowmobile Asphalt Drag Racing Association) is an organization that runs 2 classes for snowmobiles. Bracket and Pro Stock 800. Check out their FB page and see some of the greatest tar racers from all over United States and Canada!
THUNDER PRODUCTS CLUTCHING weights and components... Not just for racing. We have many replacement parts for your snowmobile clutches.
Vintage sled, lower CC sled and even Quad clutch owners should know that Thunder Products Clutching has weight arms for you! Weights go down to 37 grams and can be loaded to over 58 grams with the correct hardware included.
Kurt Schultz is no stranger to racing and wanted to try something different from his own setups, using all kinds of OEM weights. Now Kurt doesn't have to carry a bunch of weights around as his new Thunder Products Clutching adjustable weights that can be adjusted to exactly his needs....which really increased numbers on the track dyno!
