Proaction maintence
JROCK
Ottawa, Ontario
Canada
2006 Yamaha Apex GT
I have my rear skid apart on my 04 and plan on changing all the bushings! what is considered normal wear on the 3 main shaft? Don't really know there proper names, in 6000km i only had 2 bushings that were cracked and worn out which led to wear on the shaft! If i dont change the shaft will these led to premature failure of the new bushing?
Thanks!!
You don't need to CHANGE the shaft, but you should definitely FIX it. Options are; lathe and sleeve, weld and lathe, JB weld and file. JB weld is obviously the easiest and cheapest fix, probably strong enough to run against a plastic bushing...
Thanks LB! for $235 for all three shafts ill will get them machined!!
