Ellis
I rode my wife's 2007 phazer gt for the 1st time today. It ran very good down the road, then when I came back to the house the engine light came on (blinking steadily) and it wouldn't let me go forward. It seems like it went into a "fail-safe" mode??? When I turned it off and re-started it the light was gone. I repeated my ride and had the same issue when I slowed down to turn the sled around.
Has this happened to anyone else? I'm hoping it is a quick fix!
Thanks,
Ryan
Thanks,
Ryan
Granahan378
Thats odd, did it flash any codes? Fresh gas? Good oil level?
terret725
look for a number that flashes at the same time the light is on. if its any kind of problem a code number should flash. then look up the number and then u know ur problem. also when ur low on gas the caution or engin light flashes and the gas gauge will flash. u could just be almost out of gas
rhino_live
if it wont let you go forward it almost sounds like something set off the tors...i could be wrong though.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
+1 on TORS...does it happen as soon as you let off the throttle?
Ellis
Ricketts said:+1 on TORS...does it happen as soon as you let off the throttle?
Yes, it does happen when I let off the throttle. What is the TORS??? HOw do I fix it.
Thanks again!
terret725
has it been out side in any freezing rain? or did it rain and then droped below freezing and hasnt warmed up yet? if so u may have some ice in the area where ur throtel pivots. this is also the area that activates the tors. i would start there if u keep it where it been below freezing lately. just use a hair dryer and melt any possible ice or water in there. if its been warm and not below freezing is ur phazer new or used. or do u know if its still under warenty? if it is bring it in and they should be able to adjust the cable to specs and that should fix the problem.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
TORS is a throttle override safety feature...Terret725 is right, if the throttle cable or a pivot or something has ice on it or has froze for whatever reason, if goes into a safe mode, that way your throttle doesn't stay open and your Phazer doesn't plow into the far end of a lake, or a tree or something. I lost an uncle and a friend back in the '90's on machines that didn't have this feature.
Rick
Rick
