rx1 fern
installed ecp with evac and gp1 exhaust and now my sled seems like it is missing it also sputters when you punch it out of the hole
Sled Dog
Read the instructions. Go get your carbs syncronized. How is the snow up there I used to live in Gillam where you always had snow. We got a couple of inches here finally. Could also be the Tors acting up.
yamahajunkie
did you follow their directions to a tee?
rx1 fern
got lots of snow.I followed the instructions and syncroed carbs and still does what i said it did .sounds like it missing could it be electrical.
rx1 fern
also if the coils are all arcing could this be a problem
yamahajunkie
what elevation are you at? how many turn on the screw on the bottom of the carbs?
Sled Dog
Thompson Manitoba might be 400 meters above sea level.
rx1 fern
i went with 2 and a half turns counter clockwise.also i jetted to 170 mains
yamahajunkie
2.5 turns then still?
yamahajunkie
try putting the plug you had in it b4 installing kit. could have fouled when syncing carbs. worth a try.
Sled Dog
Observed At: Thompson, Manitoba
Elevation: 715 ft / 218 m
rx1 fern
put new plgs in cr 10 ek and slill does it .could it be the coils
rx1 fern
thinking of taking exhaust off
SIMMER
Make sure you didn't remove the WRONG jets.....the mains are easily confused with the pilots.
My buddy did it and had the same problem.
yamahajunkie
unhook tors to test. other wise you may have to back track in carbs. o-rings jets in right spots.
i thought it came with 165 jets?
