Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
My '06 Apex RTX came with a Proline clutch kit installed. Is this a decent clutch kit? I was hoping it was good and don't need to get anything different. Otherwise, What in your opinions is the best clutch kit/set up for this sled? Thanks.
- Sauk Prairie, WI
- www.ty4stroke.com
Run stock clutching with a white secondary spring and a 40 bottom (or 23 top) gear. This setup will outperform the Proline kit on any surface. Been down that road before.
SledFreak
- Feb 7, 2005
- Ontario. Canada
BlueByYou2000 said:Run stock clutching with a white secondary spring and a 40 bottom (or 23 top) gear. This setup will outperform the Proline kit on any surface. Been down that road before.
Also lighten up the stock weights and replace the inner and middle (stock 4.6G) holes with 3.6g of revit weights and leave the tip stock. That will bring you to 10,500-10,600 out of the hole and pull harder midrange.
vice108
Snowaddict said:My '06 Apex RTX came with a Proline clutch kit installed. Is this a decent clutch kit? I was hoping it was good and don't need to get anything different. Otherwise, What in your opinions is the best clutch kit/set up for this sled? Thanks.
You will always get different opinions on this. I love the proline setup. If you have GOOD TRACTION it will rip. That being said, the stock clutching is very, very good on this sled.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Where is proline the company based out of? Looking to talk to the owner as he helped set up the sled I just bought thanks!
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
clutching
Thanks for the input. I figured I'd get varied opinions. The sled is studded (unsure of how many, but at least 144.) I'm more of a top end guy myself, but do want to get out of the hole good. Next question then may have been answered already, but what gear setting then? Is it better to change top or bottom? or both?
vice108
Re: clutching
I would go with the 23 top gear which is what comes standard on the Attak. You will gain acceleration without loosing top-end since the stock 24 gear is too high.
Snowaddict said:Thanks for the input. I figured I'd get varied opinions. The sled is studded (unsure of how many, but at least 144.) I'm more of a top end guy myself, but do want to get out of the hole good. Next question then may have been answered already, but what gear setting then? Is it better to change top or bottom? or both?
SledFreak
- Feb 7, 2005
- Ontario. Canada
Re: clutching
If you want top end, then nothing beats the stock clutching. Run the 23 top gear. 23/38 is what you need to run.
JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
Helix
Anybody know what the angle is on the dalton helix that comes with the proline kit, it is stamped 02NB if anybody knows or has measured it.
