Vmax4creed
I am having troubles displaying A/F it just says rdy & the RPM is at zero i am hooked into the cam sensor. I dont have the manual do i need to reset anything on the box?(I also tried another O2 sensor but still says rdy.)
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Tsrracing
Hey did you get your afr to work?
Vmax4creed
I did get everything working with the prologger , the RPM had to be set for 1 cylinder to read correctly for some reason. The AFR i believe i wasn't waiting long enough for the 02 sensor to run its cycle. My AF on the autotune came on quicker & they read .2+/- of each other as of now.
Tsrracing
That's good to know you got working. The afr on prologger when sled is running n says rdy hit the down arrow. Activates fast warm up mode. Takes a few seconds
