Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
When my 22 SRX is idling I can hear a pulsing noise in the engine compartment , that I have never heard before .
It seems to run fine , but it appears to be a new sound .
Anyone else have this ?
Can someone send a picture of the right side of the engine , to make sure all is normal .
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Sounds like it heated roll over valve my buddies new cat does same thing.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
So it appears that the cause of the pulsing noise it that I am missing the black screw that is shown on the attached picture , up at the top middle .Sounds like it heated roll over valve my buddies new cat does same thing.
What is that ? the rollover valve ?
Is it ok to drive without it ?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Thats where the original ROV used to be mounted. It is not open to the tank.
The ROV is now under the steering post over the valve cover.
The noise you hear is the ROV venting to the airbox. The noise is not a problem.
Kevin
Weird
The fist time I heard that noise was when I was in Gaspe Bay two weeks ago
Got back home to find my oil tank seal was leaking
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Why is that black screw there to do ?Thats where the original ROV used to be mounted. It is not open to the tank.
KnappAttack
- Feb 19, 2004
- Welch MN
Hold the valve that was there originally. You had a 17, you should know this.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I had a post about that noise a couple weeks ago. It is the roll over valve pulsing which is now vented to the air box. Either delete ROV or reroute hose to the 1/2” fittings where it used to go on the intake manifold just before turbo. It’s capped off on my 22. It will be muffled there and you won’t hear it.
It’s crazy annoying sound
I originally thought it was BOV I rerouted it to the 1/2 fitting. Next time I’m working on sled I’m pretty sure it’s going to get deleted. As I’m typing this I thought about the snot that’s going into he after cooler.
Weslemkoon
- Sep 30, 2021
- ONTARIO
- 2022 Sidewinder Ltx GT PS
This noise is annoying for sure. I never really noticed it much at first but it's all I hear now because it's there lol.
Are there times where it's better or worse? Cold, warm up, long runs. Can't really figure it out.
Other than this....sled is freaking awesome in every respect...um, except weight. It's quick and rails.
2022 LTX gt eps.
2022 LTX gt eps.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Just read my post. I wasn’t very clear
i rerouted the rollover exit hose from the air filter area are ( I have CAI that made this sound even louder ) to the 1/2” fitting over by the turbo. I believe it’s the fitting the earlier models used for the roll over valve
Weslemkoon
- Sep 30, 2021
- ONTARIO
Thanks a ton! You must be annoyed at responding to this every 6 months lol.Just read my post. I wasn’t very clear
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Not at all
Kinda embarrassing to post a vague post like I did previously that helped no one
There are lots of hacks to be learned on this site. Very valuable asset when one has the desire to make something that pretty awesome even better
