ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
As I mentioned, that is from Tcat. And very well likely coming on the 18s.Oh ya, I like it? Where from? I want one!
Sent from my SM-T705W using Tapatalk
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So here’s the final drawing of my push button start. If a guy uses a button with contact ratings large enough you could skip the relay and just install the timer relay. I wanted to use the skidoo brake and rer cluster. The timer relay is from amazon ....it works well. http://timers.shop/
I tied into the hood harness by the grey plug.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Couple more of the skidoo rer button and key switch wiring. Disregard Sketching just rough and probably incorrect. Just shows where I tied in.
HighSpeedLowDrag
I've had a handlebar mounted push button start switch on my apex for close to a decade which works very well. I don't understand why you would use a timed relay. Wouldn't this energize the starter for a fixed length of time no matter what is required and even stall and overheat the starter if the battery runs down before the engine starts and time is up?
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Well in the drawing the timer is only there to power the push button switch for timed duration. After that, pushing the switch will not kick the starter over accidentally while riding. Power cycle resets the timer.
- Apr 14, 2003
- Hessel, Michigan
Thank you guys for the wiring diagrams....I'm hooking up a remote start to my Winder.
How does the Doo Master Cylinder feel? Not talking the lever I am talking one finger or two and is lock up at top or near bottom of pull?
craiger68
- Jan 10, 2008
- Wausau, Wisconsin
- 2020 SRX LE
2020 Viper LTX GT
2007 Attack
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
I wish somebody or company come up with a plug and play kit like this. I’m after coming across really high quality push buttons on the web for good prices.
srx700lt
- Mar 29, 2006
- Sweden
- Sweden
- SW XTX-146 SE
Would it be possible to rewire this so that one can use the revers button as starter button and put another button for reverse somewhere else?
RAMSOMAIR
Can you please share details on your system? PM sent also.
craiger68
- Jan 10, 2008
- Wausau, Wisconsin
- 2020 SRX LE
2020 Viper LTX GT
2007 Attack
I bought a 50 amp tractor starter button, and jumpered the starter wires from the ignition switch. when the key is on, the sled will start with the button, same as the key switch. with the key off, the starter will still spin if you push the button, so you only have to remember to leave the key on.
Be sure to buy a DC push button, not AC. the original button on that video was replaced that same week once I read up on AC vs DC switches. An AC switch will fail in a short time on DC power.
I generally left the key on and used the kill switch to power up and down. this does not drain the battery, off is off, same as the key. Used this for three seasons and 10,878 miles with no issues.
Craig
Joshua
- Apr 14, 2010
- Newfoundland
Any pictures?
craiger68
- Jan 10, 2008
- Wausau, Wisconsin
- 2020 SRX LE
2020 Viper LTX GT
2007 Attack
Any pictures?
Only the video above that I posted in 2017 . I sold that sled in September, so no other photos are possible.
Craig
- 23K
