tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
It sure would be nice if a rider could hit a bar mounted button that would activate an exhaust butterfly to tame a loud exhaust when needed. Seems like noise restrictions are getting more strict each year. Anyone see any kits available? Maybe something for BOP to look into? Travis?
guardrail
https://www.summitracing.com/parts/...shopping-_-srese2-_-pypes-performance-exhaust
You would have to adapt it to your pipe size
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
XYZ made some for the Z1 turbo cats. Jaws currently makes one for the sidewinder, quiet when cruising and a baffle opens up when the boost hits a certain psi.
tnc110
- Jan 5, 2015
Jaws $1050 for silencer!
kinger
I am making my own with a loudvalve boost activated cutout. I will reroute exhaust through a muffler then when boost hits 6 psi it will open up and turn into a full 3" tunnel dump. I am welding it next week and hoping it will tame the beast for the trails and only really disturb the deer when I hit the go lever
tnc110
- Jan 5, 2015
Nice!I am making my own with a loudvalve boost activated cutout. I will reroute exhaust through a muffler then when boost hits 6 psi it will open up and turn into a full 3" tunnel dump. I am welding it next week and hoping it will tame the beast for the trails and only really disturb the deer when I hit the go lever
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Thats what the 1050 Jaws silencer does I believe. Opens at 6psi. Just one thing, when you're cruising higher speeds, you will be more than 6psi and your exhaust will open the whole time pretty much.
kinger
That's a good point rail road beds may get old. Thankfully most of my riding is NOT like that and its a lot of open closed throttle. You can run a manual boost control (MBC) valve and have it open at say 8psi if your always in 6 when cruising. I am tempted to loop it into my MBC and have it open at WOT only just to try it out.Thats what the 1050 Jaws silencer does I believe. Opens at 6psi. Just one thing, when you're cruising higher speeds, you will be more than 6psi and your exhaust will open the whole time pretty much.
