stoutner
laker,
I pm'd you but it is taking forever to go through.
Quick question, Where can I buy the tool to remove and install the valve springs in the Cylinder head? What is the tool called??? Or, How can I do it without any special tool?
lakercr
Tech Advisor
stoutner said:laker,
You can order the proper tool from Yamaha, Motovan, or Orient Express.
To remove the valves you can take a 10mm deep socket, put it over the retaining cap and give it a quick wack with a rubber mallet - the keepers will fall right out. You can also just take the head to a Yamaha dealer and have them install the valves if you don't want to spend the $ on tool you'll (hopefully) never use again.
you'll probably find ordering a valve shim kit from www.hotcamsinc.com much cheaper that getting them from Yamaha. The attached .xls will also be useful when it is time to re-shim.
True Blue
Shims ......
Jim
Did you try and order the shims from this site ??? Must be some
kind of shims.........
TB
Jim
TB
lakercr
Tech Advisor
Woops!!
Post edited with the proper address...
Or follow this link:
http://www.hotcamsinc.com/index.cfm?fus ... nter=Go%21
True Blue
Caught you Jim, now we know what you do in your spare time. besides Turbos...
TB
TB
lakercr
Tech Advisor
True Blue said:Caught you Jim, now we know what you do in your spare time. besides Turbos...
TB
Spare time? I'm not familiar with the term...
True Blue
I hear ya...
TB
TB
stoutner
very helpful. Thanks guys. You are saving me some more time!!!
