mazak500
Just got my nytro broke in. Need to change oil. What kind of tool do you guys use for the quick snap fasteners? i already broke 2.
DeerHuntr
I went to a auto supply store and bought a bought a box of 25 of them that are almost identical to the yamaha ones for like $10. When i did the oil change I used a tool that is used for removing door panels and just put all new darts in when I reinstalled. I bet I had all the plastic off in 5 minutes or less, worth the $10 bucks to me.
usafracer
Same here I think I broke all but one. I went to napa and handed them the pile of broken ones and said I need these but in one piece. The guy just laughed. Turns out he owns a Nytro too.
mazak500
That sounds good to me. thanks alot
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
if you guys have a part number it would be handy thx
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
put a small blade screwdriver under the side with the slot and pry up - i had every one off the front plastic on my son's nytro and didn't break any of them.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
ya thats what Ive done..works great...just in case thowoolyviper said:put a small blade screwdriver under the side with the slot and pry up - i had every one off the front plastic on my son's nytro and didn't break any of them.
BooBoo
Yup x2 because some will brake for sure. I always have some on hand. sj howed your U.P. trip go?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
not too bad considering I had a hell of a head cold! not the best time to be tweaking and tuning but had to go while the snows there...
how bout you guys?
how bout you guys?
BooBoo
Had a good time, Cold for sure. My RSI bars kept me warm, First time I got to try them out in that cold of weather, very happy with them.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
someone said the rsi's will burn out if you do the hi-lo install? better to do just the hi heats...if you get a chance..p.m. me your setup as I like the idea of a better bar too..
DeerHuntr
The ones i buy have the number 2889 on the box and the discription reads "Plastic push rivet fits 8mm hole, 20mm head, 13.4mm length. Honda/Acura '94 & up. They look very close to the oem Yamaha ones but the head is a bit bigger. Been using them since last year with no issues and I just bought another box today for 12 bucks at a autobody supply store. Sorry about the pic quality, need a new phone.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
thx for posting recommend sticky
ingersoll113
yup
Yeah I broke a couple and got humped at the dealer. I found out since that Fastenal has them too fyi guys.
bradb
i bought one of those cheap small end nippers at the hardware store and did a little custom grinding on it. Pulls them out perfect and doesnt wreck them like screwdriver at all
