Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I'm going deaf, literally. I have tinitus in both ears. I've always found my MP loud. Is there a quieter muffler I could add on? Im planning to do the tunnel close off to enclose the exhaust and exit to the rear after this season.
Maybe a bike muffler? Quad? Car?Since it will be enclosed, I don't care about looks. Muffler on there now looks like a small car's.
Surestick
- Jan 19, 2015
- '07 Phazer Mountain Lite
I find most of the noise on Phazer comes from the track unless I'm really on the throttle. I wear ear-plugs under my helmet but the noise is really low frequency and cuts right through.
wacnstac
I hear ya Moose, actually.... not very well after being on my Venture Lite all weekend.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Riding it yesterday, I noticed it's more the intake noise I hear. Exhaust is lower tone but may be reverberating in the tunnel. I used to have it piped out the back but the flex pipe I was using rotted out. When I do my tunnel enclosure, I'll redo it hopefully in stainless along with header wrap for the heat, which may also help with noise.
I don't think there's anything I can do with the intake noise. I know cars and trucks use resonators to attenuate that but it's mostly at higher RPM noise is an issue. Since these engines are so high strung and almost always in 10k RPM, intake noise is more prevalent.
Ryking93
- Dec 16, 2018
- Newfoundland
- 2014 Yamaha Venture Multipurpose
I find between 40-55kph it's perfect. But after 55+ I find it's so loud it'll make you dizzy after prolonged use.
Did you find extending the exhaust out the rear suppresses some of the noise?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I think it did at the time. I just completed the enclosed tunnel and exit out the rear but we don't have enough snow here yet. I did trailer and ride a bit in North Bay on the weekend before and found it quite loud. Might even be responsible for my permanent tinnitus.
You should also check your donuts as mine were gone fairly early in its life, which I replaced with copper donuts. If you find your exhaust loud, this is a possible source.
Ryking93
- Dec 16, 2018
- Newfoundland
I find it significantly loud and I’m not sure if it’s a mixture between the exhaust, intake, or tunnel/track
What do you mean by donuts,
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Exhaust donuts.
https://ty4stroke.com/threads/copper-exhaust-donuts.94508/
However, looks like Sledtoyz is gone. Ulmer Racing has them but at a significantly higher cost. There is another fix I found.
Flex joint/donut elimination kit
I have had the flex joint fail on me as well as the pipes crack. Could have been me since I haven't heard of others suffering such catastrophic failures, at least not on these sleds.
YukonMP
- Dec 25, 2014
- Yukon Territory
Looking forward to your report on your mods Mooseman, hopefully you will get some snow. I wear ear plugs on any extended runs of 5 minutes or more.
I think the problem with the MP muffler is that the damn thing is so solid it is going to last forever and I'm never going to get to try something else.
Ryking93
- Dec 16, 2018
- Newfoundland
Exhaust donuts.
Ohhhkk,
So the exhaust cracking/separating is a common thing? I haven't even inspected mine to see!
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Like I said, mine has been the only one I have seen fail on this platform although my son's flex joint failed on his '09 Phazer, but he abuses it badly.
I'm hoping the noise is down. I'm probably gonna have to trailer to Pembroke or North Bay. Ear plugs are ready just in case.
MikeWalters
Take the airbox lid right off and try it. It will be louder, but the resonance will be much different. Just don't try it when its raining LOL. Might point to the culprit whether its exhaust or intake that bothers you the most.
Ryking93
- Dec 16, 2018
- Newfoundland
So, after 300km's this weekend I have narrowed the noise down to the exhaust/track. I can differentiate noise from intake and exhaust/track.
I think the main noise I am hearing though is my track, again after 55km/h it increases and gets very loud. Has anybody remedied this?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Without having done any real riding and just going around the yard, I found my exhaust is quieter. Probably because it goes straight out the back and doesn't reverberate in the tunnel. I'll be posting about it at some time.
I can't say anything about track noise since mine isn't the stock one.
Ryking93
- Dec 16, 2018
- Newfoundland
What track are you running, and do you notice that it’s loud/quiet?
Also after looking my track is half clipped, also definitely will need new slides this season
