vicman
I just got my shock back from pioneer. I'm outing the rear skid back together now but don't have the rest of the sled here. I need to know which way on the RA adjusted is the hardest setting. Toward the front of the sled (counter clock wise) or toward the rear (clockwise). Thanks again. Can't wait to ride the sled with the heavier spring rebuild and revalve!
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Turn the dial counter clockwise for hard.
Shootinstick
As I remember though, the cable to the shock turns the opposite direction as the dial.
vicman
thanks i just needed to know which way on the dial was hard before hooking it up to the shock.
Capt.Storm
Shootinstick said:As I remember though, the cable to the shock turns the opposite direction as the dial.
Yep.
If I remember right you want to set the shock by hand to hard then the dial to hard then hook it up.
